K20A2, What AFR to tune for E85??
AllMotor787
Post by AllMotor787 »
Well with gas prices the way they are, I have been considering goin the E85 route since it's much cheaper than 93 octane around here.
My question is:
What kind of special tuning will I have to do to get my car to run properly on E85?
Do I tune it to the normal air fuel ratio's for NA? (14.7 @ idle, and 13.0 @ WOT?)
Anything else I should know before filling up with E85? Will my stock 310cc injectors be enough?
Thanks!
-Cody
ce
Post by ce »
The AFR for e85 is different. The lambda however is similar.
Here's a link with some info:
http://www.experiencefestival.com/a/E85 ... id/1345236
You need to upgrade those injectors. E85 requires a lot more fuel, I've seen people needing 50% more when switching to e85. A high flow fuel pump is probably also a good idea
K is king
