Stock Fuel Pressure
Posted: Fri Aug 08, 2003 4:06 pm
What fuel pressure should my car be set at for Hondata Base Maps I'm comparing the P30 and P72 base maps.
Also a related question, is there any body that can tell me why a P72 base map has a shorter injector duration(about 14ms peak) than a P30 base map(about 17ms peak)? The GSR has higher fuel pressure but .2 more displacement?? The duty cycles are also lower for the P72 map.
Thanks,
Thanks,
