HELP, HELP.
Posted: Fri Aug 15, 2008 6:03 pm
by rochy01
hello everyone,
I'm new in this forum and in hondata as well, i got a s300 and i have not clue how to make it work to change the fuel maps. i was trying to go over the help section and online tutorial but is not really helping because the help section have more general information and not specific and tutorial mmm not really for Smanager. i got the base map from this forum NEW D16Y8 and i change the injectors size with the map sensor as well 3 bar.
my setup is this
stock engine D16Y8 honda del sol SI 97
t3/t4
Compressor Specs :
3" Compressor Inlet
3.000" or 76.2mm inducer
1.990"" or 50.55mm Major
Compressor .50 A.R.
Compressor 57 Trim
M24 / T4 Compressor Housing
Turbine Specs :
T3 Type Turbine
11 Blade Type
2.25" Exducer
Turbine .64 A.R.
Turbine 76 Trim
2.567 " or 65.2mm Major
2.207 " or 56.06mm Minor
Exhaust Outlet Flange with 5 bolt design
255lp fuel pump
550cc peak and hold with a resistor box
OBD1 P28 with S300
high flow Cat
AEM Wideband A/F gauge and sensor ( is not connected to the ECU)is standalone gauge
if somebody can get a map so i can run this car i will appreciate, because i spend i lot of money all ready and i can even enjoy the car.
thanks
Rodrigo
Posted: Sat Aug 16, 2008 5:07 am
by cardinal811
Find a TUNER, you can afford the Hondata you better be able to afford a tuning session
