Gear Comp... RECALC GEARS function ??
Ratman
Post by Ratman »
How does it work..
we have problems.. have put in the correct rations. but don't work..
could be nice to se the current readout of ration, when on the dyno..
for calibrating the rations..
/Rat
What version of software are you using from Help, About?
Ratman
Post by Ratman »
Spunkster wrote:What version of software are you using from Help, About?
Using 1.3.8.0
a search in help for "recalc", returns "NO tropics found"
would just like to know how i works..
are you to do a run trough the gears in a special manner ?
/Rat
Recalc is just used for reviewing a datalog if you change the gear ratios.
Help file updated.
Ratman
Post by Ratman »
Spunkster wrote:Recalc is just used for reviewing a datalog if you change the gear ratios.
Ok.. That is perfect.. because we have some datalogs that is with wrong rations... THX :)
also, now we can se if rations is correct.. ;)
/Rat
