K PRO and PRA E02
Posted: Sat Aug 09, 2008 1:32 pm
by fei
Hi
i have a euro CTR 2002 and my ecu is a PRA E02 and plus i have a JDM wideband o2 sensor (because now i'm running another ecu)
So will it work fine PRA E02 for K pro upgrade? Can i use my wideband sensor?
thanks for the reply :)
bye
Posted: Mon Aug 11, 2008 7:49 am
You need the stock narrow band o2 to run in closed loop, however if your wideband has an analog output you can feed that into the ELD input for datalog and display.
Posted: Sat Aug 16, 2008 10:15 am
by fei
Hondata wrote:You need the stock narrow and o2 to run in closed loop, however if your wideband has an analog output you can feed that into the ELD input for datalog and display.
wideband is the stock jdm honda,so can't i use this with k pro? maybe some bridge on the pin of the ECU?
And someone told me that,there are problems with some version of the PRA ecu and K pro.. it s true?
thanks
Posted: Mon Aug 18, 2008 7:21 am
The PRA ECU will only run a narrow band o2. A wideband o2 can only be used with the PRB/PRC/PRD/PND/PNF ECU.
As for rumours and heresay ... they are just that.
