Car not starting!!!
Posted: Tue Aug 05, 2008 8:28 pm
To start i just bought this car like a week ago. worked fine.Ok so this morning i connected my hondata to my laptop download the calibrations from the ecu to see what was set in the parameters. I noticed the VTEC wasnt enabled so i enabled it. also noticed the rev limit was at 39000(yes 39000) so i dropped it down to 8200. i saw some error codes so i went up to online and cleared dtcs. i uploaded the new calibrations and BOOM! wont start. it cranks but it wont start. so i downloaded it again and put everything back where it was and still no go.
I dont know how to do the calibrations attachment so ill just type it.
FUEL TRIM
stock inj. size 180
current inj. 550
overall fuel trim -100%
crank fuel trim -100%
throttle tip in trim 74%
cylinder fuel trim
#1 -125
#2 -4
#3 -75
#4 -25
cold start
-56%
REV LIMIT 8200RPM
REV LIMITER TYPE- FUEL
CUTOFF 8000RPM
LAUNCH CONT. DISABLED
FULL THROT. SHIFT DISABLED
VTEC ENABLED
OIL PRESSURE SWITCH ENABLED
VTEC WINDOW
low 0rpm 30inch.
upper 256rpm 30
min throt. 0%
min speed 80mph
min temp 85f
IAB SWITCH POINT 1953RPM
IDLE
MIN IDLE SPEED 700RPM
IAC DUTY CYCLE NORMAL
DISABLED IAC EROR ENABLED
MAP STOCK
SHIFT LIGHT 1000RPM
CLOSED LOOP
DISABLE
DISABLE O2 HEATER ENABLED
MISC
DISABLE KNOCK SENSOR CHECKED
DISABLE ELD CHECKED
DISABLE BIOMETRIC PRESSURE SENSOR CHECKED
INVERT PURGEVALVE CHECKED
thats about what i got anything else just LMK.
heres my car:
1995 integra gsr 4 door
2000 b18c1
CTR oversized pistons
typr r rods
JG HEAD with spoon cams
WALBORO FUEL PUMP
P28 HONDATA S300
PLEASE HELP!! THAT WAS A LOT OF WRITING!!! :lol:
FUEL TRIM
stock inj. size 180
current inj. 550
cylinder fuel trim
#1 -125
#2 -4
#3 -75
#4 -25
cold start
-56%
REV LIMIT 8200RPM
CUTOFF 8000RPM
VTEC ENABLED
VTEC WINDOW
low 0rpm 30inch.
upper 256rpm 30
min throt. 0%
min speed 80mph
min temp 85f
IDLE
MAP STOCK
SHIFT LIGHT 1000RPM
CLOSED LOOP
DISABLE
MISC
DISABLE ELD CHECKED
heres my car:
2000 b18c1
typr r rods
WALBORO FUEL PUMP
P28 HONDATA S300
