Injector duty cycle question
Posted: Tue Aug 05, 2008 2:08 am
by bossman032
I was wondering running injectors at 97% duty cycle will this damage the engine?
at about 7600 rpm...I know hondata says upgrade injectors about 80% I think..
I want to upgrade but don't want to if it won't do anything.
thanks! :P
Posted: Tue Aug 05, 2008 9:27 am
You are maxing out the injectors. You need larger ones.
Posted: Thu Aug 07, 2008 10:13 pm
by bossman032
does changing injectors require re-tune? I am going to swap over to rdx injectors. I am aware I need to change the values in the kmanager software. I was wondering do I need re-tune after swapping injectors?
thanks!
Posted: Fri Aug 08, 2008 8:44 am
Different injectors will require some re-tuning, usually around low injector openings. The easiest thing to do is to raise the fuel pressure.
Posted: Fri Aug 08, 2008 9:34 am
by Axix23
how do you raise the fuel pressure with no fpr?? Can Kpro do that? :)
Posted: Fri Aug 08, 2008 12:12 pm
No, you must have an adjustable FPR.
