Honda IAT Sensor
tmartin
Honda IAT Sensor
Post by tmartin »
I am working on a aftercooler project for a JRSC on a 06 RSX Type-S which is finally complete outside of some IAT sensor issues. I have been working with some GM type IAT sensors such as the SU109 closed type and open type. Do you guys have any experience with using sensors to monitor boosted temps within the intake manifold? I have heard to use the integra iat sensor but are there other IAT sensos that work better and more importantly read quickly? I want to ensure of the temps within the intake manifold before I start upping my boost levels anymore.
You cannot use a faster sensor as the ecu only reads at a certain rate. USe the suggested INtegra sensor, as it has the same characteristics as the RSX sensor and will read the same which is important for the ECU.
