PRB Conversion PRA Car, a different way... possible?
Posted: Thu Jul 31, 2008 10:50 pm
Quite simple and straightforward question:- Remove the pink wire from connector E4 (signal ground 3) and connect to A16 (Primary Heated Oxygen sensor - ). This is best done with an AMP pin removal tool. A16 is unused on the UK Civic Type R harness.
- Unplug the rear oxygen sensor and disable OBDII in K-Manager.
- Connect A22 (use a T-Tap) which is unused on the UK Civic Type R harness to A2. This provides a switched 12V to the ECU to tell it that the oxygen sensor heater is receiving 12V and working.
Cant I just wire the pink wire of the primary O2 directly to A16, that way I can leave the secondary O2 sensor alone(and keep it connected) and don't have to disable OBDII?
