PRB Conversion PRA Car, a different way... possible?
Sandaman
Post by Sandaman »
- Remove the pink wire from connector E4 (signal ground 3) and connect to A16 (Primary Heated Oxygen sensor - ). This is best done with an AMP pin removal tool. A16 is unused on the UK Civic Type R harness.
- Unplug the rear oxygen sensor and disable OBDII in K-Manager.
- Connect A22 (use a T-Tap) which is unused on the UK Civic Type R harness to A2. This provides a switched 12V to the ECU to tell it that the oxygen sensor heater is receiving 12V and working.
Quite simple and straightforward question:
Cant I just wire the pink wire of the primary O2 directly to A16, that way I can leave the secondary O2 sensor alone(and keep it connected) and don't have to disable OBDII?
Mr Aryan
Post by Mr Aryan »
would love to know that too
Sandaman
Post by Sandaman »
Since I get no answers, let me put it this way:
Is E4 on the PRB ecu used for the secondary O2 like on the PRA ecu?
kistian
Post by kistian »
I've developed a scheme for this propose
it's not tested, but I think it's right on schemes, can you finish that develop trying that
te complete info is here (in spanish): http://www.foroctr.com/viewtopic.php?f=16&t=489
