Page 1 of 2
Euro PRA w/ oem RSX O2 wideband in ELD pin possible ????
Posted: Wed Jul 30, 2008 9:32 am
by brunoctr
hello
can i connect an oem rsx wideband into eld pin of a pra kpro to datalog the air/fuel just like any other aftermarket sensor ????? were can i get the values for the lambda conversion table ??? are they already there in the "stock" option ????
this is cause allready have a pra w/ kpro. if it was stock of course i would prefer to get a prb w/ oem O2 rsx sensor
thanks
Posted: Wed Jul 30, 2008 10:00 am
by Garrett_si
The best and simpliest way
is to use a USDM ecu
Posted: Fri Aug 15, 2008 6:26 am
by LK7R
PRA ECU does NOT have a WideBand Lambda controller -> on ELD pin you have to connect output from aftermarket WideBand controller to which is connected Lambda sensor.
Options are:
1) PRB ECU and resoldering KPRO into that ECU + some wiring changes (you have Euro CTR right?)
2) Buy an aftermarket Lambda sensor with controller (such as AEM UEGO or INNOVATIVE Motorsports LC-1 or LM-1, ...)
Dan
Posted: Fri Aug 22, 2008 7:56 am
by carbonctr
LK7R wrote:PRA ECU does NOT have a WideBand Lambda controller -> on ELD pin you have to connect output from aftermarket WideBand controller to which is connected Lambda sensor.
Options are:
Dan
From experience do NOT fit the LC-1 sensor in the primary position to simulate the narrowband stock sensor by wiring directly into the PRA ECU's primary o2 input pin (A6?). I did this and the car ran terribly in closed loop. It might work by wiring the LC-1 narrowband output to the stock sensor's connector plug as I didn't try that. I have put the LC-1 in the secondary o2 position so the stock primary one could run the car properly. There are voltage offsets on the ELD pin in my PRA ECU so I had to calibrate by setting the LC-1 to flatline a few set voltages to make a conversion table. But it now works well and I get nice AFR values for datalogging from the LC-1 :-)
Posted: Fri Aug 22, 2008 9:59 am
We only recommend the PLX Devices widebands.
Posted: Thu Jun 18, 2009 6:10 am
by LK7R
I have Innovate Motorsports LC-1 hooked up to my PRA KPRO ECU. I'm using it for WB and NB too.
Wiring is as follows (6 wires LC-1 version):
ECU conector A:
A6 [PHO2S+] -
Yellow wire (Narrowband O2 output)
A5 [PG1] -
Blue wire,
Black Wire,
Metalic/White wire (Ground - thick black cable)
ECU conector E:
E15 [ELD] -
Brown wire (Wideband O2 output)
E9 [IG1]-
Red wire (+12V)
Wires from LC-1 are soldered to the ECU cable harness.
Hope that it helps to someone.
cheers
Dan
Posted: Thu Jun 18, 2009 2:02 pm
by carbonctr
ECU conector A:
A6 [PHO2S+] - Yellow wire (Narrowband O2 output)
A5 [PG1] - Blue wire, Black Wire, Metalic/White wire (Ground - thick black cable)
ECU conector E:
E15 [ELD] - Brown wire (Wideband O2 output)
E9 [IG1]- Red wire (+12V)
cheers
Dan
Interesting...I might get missioned and wire mine the same some day. I would like to have the wideband in the primary position. The only downside would be if the LC-1 controller packed in again like it did a few months ago. Innovate fixed it free of charge but would mean running with the MIL illuminated in open loop for a few weeks if it happened again.
Did you just solder the LC-1 wires to the cable harness leaving the existing A6, A5, E15 and E9 wires connected or did you cut them all first?
When I connected the LC-1 first time in the primary position, I only connected the LC-1 yellow wire to A6 and all the grounds to a connector strip wired to Hondata's suggested engine earth. It coughed and spluttered and may well have wasted my 80 quid spark plugs!
Posted: Thu Jun 18, 2009 11:33 pm
by LK7R
No i didn't cut the cables. Just did a proper soldering job on the side of the cables about 3cm away from the conector and isolated them with tape. Will take picture for you. I also used conectors to make it more practical in case i youd need to unplug it or use another WB in my car. You'll see it on the photos.
I went for a trip (~1 500km) and it seems to be working fine. Fuel consuption was as expected (120km/h -> 7 to 7.5 litres/100km). No coughing and spluttering. You have to disable primary O2 heater in KPRO.
One problem was that it gave me MIL error - O2 sensor voltage is high (twice). Simple switchig off and on sorted it out.
cheers
Dan
Posted: Sat Jun 20, 2009 2:38 pm
by carbonctr
cheers
Dan
I had the same error after I wired my LC-1 up the first time in the primary O2 position with only the yellow wire connected to A6 and the grounds to the engine earth. Switch off and restart did sort it but then the spluttering started. Hopefully this is just due to a voltage offset as the LC-1 was not grounded to the A5 wire.
I would like to see the photo of your wiring. I bought a nice little gas soldering iron for doing this job originally so have the tools to do it.
Posted: Wed Jun 24, 2009 12:16 am
by LK7R
Here are the pictures i have promised. Quality is bad, but I'll take some more later with better light.
Posted: Fri Jul 03, 2009 11:11 am
by carbonctr
LK7R wrote:Here are the pictures i have promised. Quality is bad, but I'll take some more later with better light.
Nice one! Thanks for attaching the images. I'll have a go when I have the time and see how it goes....
Posted: Sun May 09, 2010 12:24 am
by bewize
I have a problem with LC-1 wired the way it's shown here. Connected it to PRA ECU, but the voltage on ELD don't drop lower then 1.35V. Why can that be? Can there be any ballast resistor in the circuit? AFR don't drop lower 11.5 this way. Don't know how to solve this problem
Posted: Thu Jul 08, 2010 5:12 pm
by zbrskz
bewize wrote:I have a problem with LC-1 wired the way it's shown here. Connected it to PRA ECU, but the voltage on ELD don't drop lower then 1.35V. Why can that be? Can there be any ballast resistor in the circuit? AFR don't drop lower 11.5 this way. Don't know how to solve this problem
Same with me ...
I find the ELD values to be in the range of 1.36 - 4.90V.
I have set the conversion table to:
1.36V - 7.350AF
4.90V - 22.390AF
The readings seem coerent with LogWorks software, but I lost confidence regarding accurate readings ...
Anyone else?
Luis
Posted: Wed Aug 04, 2010 1:23 am
by LK7R
zbrskz wrote:bewize wrote:I have a problem with LC-1 wired the way it's shown here. Connected it to PRA ECU, but the voltage on ELD don't drop lower then 1.35V. Why can that be? Can there be any ballast resistor in the circuit? AFR don't drop lower 11.5 this way. Don't know how to solve this problem
Same with me ...
1.36V - 7.350AF
4.90V - 22.390AF
Anyone else?
Luis
Same here, I'm trying to figure out way how to calibrate LC-1 with KPRO semi-automaticaly using .kdl datalog and datalog from Logworks3 software. Unfortunately there is no ELD.V data in datalog exported CSV file.
Re: Euro PRA w/ oem RSX O2 wideband in ELD pin possible ????
Posted: Tue Apr 03, 2012 1:33 pm
by Dervi
I am an
O2 user. Also i want to know about it. Please give me a solution about it. If you tell me a good suggestion then it will be very helpful to me. I am waiting for the suggestion from all of you.
