AEM UEGO Wideband Controller (30-4100)
Posted: Wed Jul 30, 2008 7:33 am
by Conquistadore
Hello,
I am planning to install an AEM UEGO Wideband Controller.
I would like to learn a few things before the installation.
There is no service arround me which may help me so I am on my own. I am depending on your advices.
I have been reading several forums for a week, here is what I understood from my readings. Please correct me if I am wrong.
1. My PRA ECU is not able to read wideband signals.
2. My catalytic convertor is in place so I can't replace the secondery O2 sensor with the Bosch Wideband because readings will not be accurate since the values before and after the Cat. will be different.
3. I will use ELD input for datalogging.
Is it OK if I will drill a hole and make a port for the wideband, somewhere near the primary (A/F) sensor.
How will I connect the wideband to ELD? Will I cut the E15 wire and solder the wire coming from the UEGO Controller to the female connector?
If I cut the original E15 wire is it going to affect any functuality? The Idle air control valve depends on the ELD for revving the engine a little faster when the AC or the head lights are on doesn't it?
Please advice.
Regards.
Posted: Wed Jul 30, 2008 9:35 am
First of all we do not recommend the use of the AEM wideband. Many poeple have problems with these and they only have one output.
We only recommend the use of the PLX widebands.
INstallation should be similar (changing only the pin numbers) as for the s300:
Since this ecu is not used in the US and we do not have European vehicles to test in, this is not something we can offer any advice on.
Posted: Wed Jul 30, 2008 11:47 am
by sk8flex
Spunkster wrote:We only recommend the use of the PLX widebands.
Any PLX wideband or are there any PLX kits you recommend? I will be using it with a PRA K-Pro as well. :)
Posted: Wed Jul 30, 2008 1:23 pm
by Conquistadore
Two questions:
1. Is "PLX Devices SM-AFR DM5 Wideband and Gauge Combo" what you are recommending?
2.
Posted: Sun Sep 28, 2008 3:41 pm
by Conquistadore
I found a private Honda Service with engine modification experience (They prepare Honda's for racing.) and have them install an AEM UEGO 30-4100 to my CTR.
I am very satisfied with the accuracy by now and will be posting my calibration and datalogs in a few minutes.
They told me that grounding and sensor installation is very important for accurate readings and they have been installing AEM UEGO's for a long time.
Sorry for not following your recommendation but I can't find PLX Widebands here. And if I buy one online I have to pay 500$ Tax at our customs. Plus it will be very expensive for me to send the gauge for repairs if something happens.
Regards.
Posted: Mon Sep 29, 2008 10:55 am
by gangaran
So do you have a wiring diagram of how they connected your wideband?
Posted: Wed Oct 01, 2008 4:30 pm
by Conquistadore
All I have is the following description:
+12 is connected to a switched power source under the fuse box with an additional fuse.
Ground is connected to the main ground. What I saw was a lot of ground cables connected to the chasis.
And the signal cable is connected to ELD Pin (E15).
I will take a picture and post here as soon as I can.
Posted: Wed Oct 01, 2008 5:34 pm
by em1
did you leave ur stock o2 pluged in? also do you have to go and change anything in parameters or anything?
Posted: Thu Oct 02, 2008 3:24 pm
by Garrett_si
I don't recommend AEM wideband too
Posted: Thu Oct 02, 2008 5:28 pm
by Conquistadore
em1 wrote:did you leave ur stock o2 pluged in? also do you have to go and change anything in parameters or anything?
My primary and secondary O2 sensors are in place. They drilled another hole near my primary O2 sensor and installed the wideband sensor there...
Posted: Thu Oct 02, 2008 5:33 pm
by Conquistadore
Garrett_si wrote:I don't recommend AEM wideband too
Why not? Have you tried one? Nobody recommends it here. Perhaps I should change it too...
Posted: Thu Oct 02, 2008 5:34 pm
by Conquistadore
Why not? Have you tried one? Nobody recommend it here. Perhaps I should change it too...
Posted: Thu Oct 02, 2008 5:37 pm
by Garrett_si
Conquistadore wrote:Garrett_si wrote:I don't recommend AEM wideband too
3 customers came with the AEM this summer to tune their cars
2 AEM was running wrong
different AFR compare to my LM-1 and my PLX M-200
Posted: Thu Oct 09, 2008 7:38 am
by gangaran
Conquistadore wrote:All I have is the following description:
So, do you have the pictures??
