KManager V1.2.4
KManager V1.2.4
KManager V.1.2.4 is available for download here
Changes:
- Added right mouse button graph zoom. This allows you to zoom in on a datalog graph area by right clicking and dragging.
- Fixed sequential shift input invert check mark not updating. If you are aren't sure if you have a sequential transmission, then you don't. Ignore this change.
- Fixed launch control / full throttle shift 'always on' input not working for PNF, PRD & PRA calibrations.
- Fixed external wideband input not showing correctly on lambda overlay. This is for S2000 and PRA owners using an external wideband via the ELD input.
- To automatically start datalogging when KManager is started use a command line parameter of 'datalog' (without the quotes). This is for car PC users so that they can start KManager datalogging upon startup.
- Added injector dead time table. This is the minimum pulse it takes for an injector to deliver any fuel, also known as injector lag or offset. Larger injectors may have higher lag times, but much depends on the injector construction. If you change this table then you will need to re-tune, especially at low throttle openings. A list of opening times may be found here, but note that the flow rates and opening times as given are slightly different as to what we have measured.
- Added cranking fuel table. This is the fuel delivered while cranking vs water temperature. The important thing to note here is that this table is already compensated for injector size, so normally you should not need to alter any values.
