swap?
capricefrk013
swap?
Post by capricefrk013 »
I have a 91 civic hatch with a 92 b18a1 swap. Can I use a Hondata cpu? If so, what can I do with it or what can it do for me? Sorry but im a noob at all this and am learning more & more each day. I run the car on the 1/4 mile and im trying to figure out how to get more without power adders right now. Plans for a turbo are off in the distance right now. Nitrous may go on soon but am still unsure about it right now. The car runs 15.33 with me being a first timer at the track. Today it ran slower because of high humidity with the best time at 15.48 with the slowest at 15.89. Thanx in advance.
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html . You can then use the Hondata s100 or s300 depending on what options you want ( http://www.hondata.com/sproducts.html ). I would recommend the s300.
capricefrk013
Thanx. Im just SO lost on all this.
