What does this mean "Added VTP as a non-multiplex AC sw
bossman032
Post by bossman032 »
Someone please explain..
I just got my ac setup and wanted to know what does this mean does this kick up the idle or something..?
What vehicle is this in?
bossman032
this setup is in a 95 gsr.
bossman032
anyone know what does this mean?
is this what bumps up the idle or what? my ac compressor is working and cycling does this mean I don't have to use this?
"This uses the vtec pressure switch input for alternate ac clutch activation when the multiplex control is not in use. Not that the vtec pressure and multiplexer must be disabled."
In an RSX the AC is multiplexed. It is not in your car. Use this input for AC to function properly. Check the Help file in Kmanager (help, contents).
bossman032
Spunkster wrote:In an RSX the AC is multiplexed. It is not in your car. Use this input for AC to function properly. Check the Help file in Kmanager (help, contents).
Yes, but how do I use this option? How do I wire it up.
I know ac works with the multiplexed in the rsx but how do I use what you said in my car..?
thanks for all your help like always!!
your the best! :D
I'm not sure what you are confused about...you simply use the VTP as the input as an alternate AC switch input like it says (one that is not multiplexed).
Garrett_si
Post by Garrett_si »
Spunkster wrote:I'm not sure what you are confused about...you simply use the VTP as the input as an alternate AC switch input like it says (one that is not multiplexed).
In which case we need to use it?
This is for use with the KPro/S2000. Please don't wind yourselves in knots about needing to use it.
Garrett_si
Hondata wrote:This is for use with the KPro/S2000. Please don't wind yourselves in knots about needing to use it.
thanks
I will need it on my s2k
bossman032
so hondata said its not used in the integra with a k series with ac?
