CAN I KPRO My Ecu if...
Posted: Mon Jul 07, 2008 10:05 pm
by burtcrx
Hi I own a crx with a 2.4 from accord with rsx head and a turbocharger
I put a PRC ecu (jdm integra type R)
The ecu has been internally bypassed to allow the car to run( and it does) but im aksing if i send you my ecu if this will be a problem to kpro it? And if my ecu will stil work when i receive it with the K pro?
Posted: Tue Jul 08, 2008 9:51 am
As long as the ecu has not been damaged or hacked up it can be used. As long as your wiring in the car has been done correctly then the ECU with a K-Pro should work.
Posted: Wed Jul 09, 2008 9:31 am
by burtcrx
Well it has been hacked but it is only from one pinout to another to alloy it to make the car run with the typeS wiring...is it ok? Thanks
Posted: Wed Jul 09, 2008 10:56 am
As I said before. Yes as long as it has not been damaged.
