Ignition values when building composite cam angle tables?
Posted: Tue Jul 01, 2008 8:29 am
I am planning on doing runs of all low-high cam angles again and was wondering if you guys actually keep ignition values at a definite number, prior to going on the dyno to tune ignition.
Reason why I am asking is because I realise in some of the base maps that sometimes you have 33degrees of ignition timing first in one column and then it drops down to 28 in the next rpm column (diff rpm column, same KPA). So I am thinking of putting it all at 32 or 33 degrees (93 RON) in columns 8-10 to make it more of a constant.
Would this be a good idea or ? Opinions much appreciated.
