Need help with my calibration.
JDM_Honda_349
Post by JDM_Honda_349 »
Im starting with the B18c 12ohm JRSC calibration
My car goes to start up but doesn't hold an idle and just dies everytime.
I have the 4 bar map and RC 550cc injectors.I have the correct NGK plugs that Hondata recommends.Im not sure if theres anything else that should need to be known to help with my calibration to get my car to idle and run well enough to make it a few hours away to go tune.
Everyones help is greatly appreciated! Lets hear what you have to say Spunkster :D
EG--B18c
JRSC
Hondata S300
I don't see a calibration or datalog showing the problem.
JDM_Honda_349
Well Im starting with the B18c Supercharger 12ohm calibration provided with Hondata.The only things I have changed about the calibration is the injector size from 440 to 550 and from a stock map sensor to and omni 4bar. Everything else is the same. As far as the datalog, I havent even got to datalog yet.Do you have to have the car started and running before you can datalog or can I do it now even though I can't get my car to start up and idle? Im still learning alittle bit so just give me an idea of what I need to do or where to start and I will get you what you need. Thanks a ton spunkster! I will be off work at 1am EST and can get you more info once I hear back from you! Thanks again.
EG--B18c
JRSC
Hondata S300
JDM_Honda_349
Well I got the car to start on the stock map sensor.I can't figure out how to get the datalog to work...When the car is running and I click datalog/record, it doesn't record anything.what am I doing wrong??
Im also getting a check engine light but its not showing up in Smanager...Why is this?
If someone can explain to me how to datalog and figure my CEL problem out then I can post a datalog and see what the CEL is for.Thanks
EG--B18c
JRSC
Hondata S300
Who socketed your ecu for the s300?
JDM_Honda_349
Hybridynamics out of PA.
It shows the time going up when I hit record but when I click "download from ecu" the new window pops up but its blank with no readings in it.The CEL is still not showing the codes in Smanager even though it throughs a check engine light every time its started. Is there possibly a problem with the socketing?If so, I can look inside the ecu to make sure its done correctly if you tell me what Im looking for.
EG--B18c
JRSC
Hondata S300
I would suggest contacting Hybriddynamics and have them take a look at it. It could be bad solder joints or improper socketing or they may not have done all the steps. Nearly impossible to say without the ecu in front of me.
