cycle is high and getting low boost
Posted: Sat Jun 28, 2008 10:31 pm
by jbcivic03
I recently hooked up my hondata boost solenoid. Its set on 30% duty cycle and only getting 11.5 psi. Does any body know what the problem would be?
Posted: Sun Jun 29, 2008 6:13 am
by mnjdmek4
are you running the stcok map sensor? you only get about 11psi for the stock map sensor.
When reporting any s300 problems, please include:
- what sort of vehicle you have
- what sort of ECU you are using
- anything about the car which has been modified from stock which may affect the ECU (don't include what sort of rims you have nor stereo etc).
says Admin
Posted: Mon Jun 30, 2008 12:17 pm
by jbcivic03
Its currently running a gm 3 bar map sensor. Its p72 ecu. civic with build gsr with sc61 turbo. I would have to see if my tuner can load the calibrations. Dont you find it odd for that cycle number and that much psi out of it?
Posted: Mon Jun 30, 2008 1:07 pm
Duty cycle all depends on your setup...each car will be different.
