A little ignition help please
Posted: Sat Jun 28, 2008 1:36 pm
Hi have a few problems.
The engine is H23 turbo and i have used an h22 basemap to start from. i have 680 injectors and are running E85
I have only been able to get it to idle at about 2000 rpm
After setting the base ignition to 15 degrees i have 47 (!!!) degrees advance at 2000 rpm and the car missfires. I made a short log where i locked the ignition to 16 ( i know shound have been 15) degrees in the middle. I'm quite the newbe at this and i will hire a good tuner but i feel lika i want to set the base so that i at least can drive the car to the tuner first. If someone can take a look at this log and my map and give me some pointers. Perhaps the engine was not all warmed up at this time. If this log is tho short i can offcorse make another one, just say the word! ;)
( please include what you want me to change and do while logging)
