Hondata Solenoid ports
jbcivic03
Post by jbcivic03 »
I purchased the hondata boost solenoid. It has 1,2,3 label for each port. Which one goes into the vacuum and which one goes into the wastegate? Then one port stays open which i think is the middle? I saw the other solenoid diagram on here, which is not that specific on the ports.
rudebwoy
Post by rudebwoy »
if its the MAC, AEM, or hondata.
with the center hole facing you, the hole on the left goes to the top port on the wastegate, and hole on the right goes to sideport TEE into the compressor housing.
jbcivic03
Post by jbcivic03 »
Thats facing the same way like in this pic? http://www.hondata.com/hondatasolenoid.html
jbcivic03
Post by jbcivic03 »
Ok i hooked it up, like u see on the picture above, but now that i am wiring the A11 part. I am running obd1 ecu and the car is obd2a. Which wiring diagram do i use.
hybridcivicls-t
Post by hybridcivicls-t »
i want to say it's A7 but i really don't remember. I will find it for you
jbcivic03
Post by jbcivic03 »
Am i suppose to tee of the compressor hose, for it to go into the lower port of the wastegate? This is the same line coming out from the right side of the boost solenoid that goes into the turbo compressor
