Starting Point for a k24a1/k20a2 frankie
Posted: Thu Jun 19, 2008 6:26 am
Hey guys, what is a good tune/preset in my k-pro to startup the following setup on so that we can tune it?
currently i just need to get the car started and running decent in order to ship back to the states as i'm military returning from overseas.
the car will be getting turboed once i get it back to the states.
K20a2 Head
K20a2 Import Builders Flat Coated Valves
NGK BKR8EIX Spark Plugs (1 Step Colder than Stock K20a2)
K24a1 Block
Wiseco K24 9.0.1 Coated Pistons
Import Builders Spec H Beam Coated (EDM Oil Hole) K24 Rods with 3/8 Rod bolts
K20a2 Oil Pump Assembly
K20a2 Oil Pan w/Baffle
K24a1 KMS Block Guard
K20a2 UKDM Type-R 6 Speed Transmission
Clutchmasters Stage III Kelvar Clutch (using the UK Type-R Flywheel)
CorsportUSA Steel Braided Clutch Line
Walboro 255lph Fuel Pump
AEM UEGO Wideband A/F Gauge w/Bosch Sensor
K20a2 Head
K24a1 Block
