Dyno sheet of my Civic Si 07 with I/H/E and reflash...
200HP EP
Post by 200HP EP »
Green line: civic si 07 I/H/E + reflash
Red line : My previous civic ep3 with K20A2 I/H/E + KPRO
What can cause the drop at 6500rpm?
A/F ratio
Compare them to the plots on the reflash page at http://www.hondata.com/reflash_06_civicsi.html
200HP EP
Post by 200HP EP »
Well, it is slightly the same shape with less torque and hp. Mine as no more gains after 7600 rpm and yours after 7900. I have a short ram intake, dcrh and evo2 exhaust. Maybe calibration of the dyno has an impact on the results.
But I still dont understand why A-F ratio become very rich above 7500rpm. It certainly drop the powerband....
What do you think!
200HP EP
Post by 200HP EP »
For the second time.... Can you explain the AFR after 7500rpm. Why does it come so rich??? :shock:
locash
Post by locash »
The 12:1 AFR isn't going to hurt anything, and if nothing else, it keeps the cylinder temps safe at high rpm.. If I had to guess, you're probably only giving up a few hp at that AFR..
Locash Racing, LLC
Hondata Sales and Tuning
Dynapack 4000 2wd Dyno
In-Shop CNC Machining and Product Manufacturing
WiL46
Post by WiL46 »
what's your set up and tpye? I got the same but my dyno has a dip and less power.
