idle problems with B16
Kai-DelSol
Post by Kai-DelSol »
Hi
After the first start the car runs at 2000 rpm cold idle and then it idle up and down from 1000-2500 rpm and the engine lit is on.
Setup:
Stock B16a2/Blockguard/ARP Headstudds
RC 440 Injectors
T25/28 Nissan Turbo/Tial Wastegate 6Psi
S300 installed/Basemap Created like the discription
Whats wrong now ?
Kai-DelSol
Here i am again.
After installing a SM-AFR from PLX Devices and a little bit tune to run the car not too lean, the idle issue was gone. It idles around 1500 rpm, a little bit high but stable.
A short test drive in 1st and second gear and some changes on the fueltables to get it a little bit Richer, it pulls good, sounds good and is driveable.
A short pull in 1st and 2nd gear and the idle problem is on. idles from 800-1500...
I use the SM-AFR only for Wideband monitoring on D10 ELD. The stock Narrowband is already connected.
On the D connector of my ECU there wasn?t a wire in the D10 ELD.
I add my map and a datalog to show what i mean.
Please take a look at this and give me a anwser.
I think that the AICV has an error.
This sounds like a problem with a vacuum leak. Usually this is at the throttle body.
Kai-DelSol
i will check all Vacuum lines today.
But why cant i get the idle to the 850 rpm ? it has no matter in open or closed loop. idle is 1500...
Kai-DelSol
Hi, Today i fixed the idle problem.
The intake mainfold gasket wasnt right.
I have some problems with the Map from the s300. The calibration File wont open.
My Laptop is Vista and my Home PC (i write here) has XP Pro.
I cant post the new Tuned map today, it semms that the Map i have postet has the same problem.
Ok... Back to topic...
I have start tu tune the car by driving and it seems all good But:
It will not rev over 7k rpm. It sonds like a revlimiter that the injectros wont add fuel over 7k RPM.
I have a Walbro 255 installed but the stock Fuelrail and the Stock Fuelpresure regulater.
Is this a Programming issue ? over 7k rpm the Injector duty cycle is over 100 %, How can i fix this ?
The calibration you have posted is corrupt. Go to File, New and create a new one and upload it to the ecu.
Kai-DelSol
How can this hapend ? is that a Bug that the file are corrupt ? in the past i had this problem one time and since then never more.
That can be the answer why the car wont rev over 7k... i will check this tomorrow. i hope that these corrupted file is not in the ecu.
Is that ok when the injector duty cycle is over 100% on High Load ?
Please give me a Yes or No to my Basemap creation procedure.
1. Stock P30JDm > Create Boost Tables (Retard Ignition .75 Degrees per Lb Boost / Add Fuel under Boost 120% naturally aspirated Fuel levels)
2. under "Fuel Trim" add the new Injecor size 440cc
3. When its too lean, Add fuel in "Fuel Trim" under "Overall Fuel trim" in %
4. Fine Tune in the Fuel Tables but not going over 100% Injector Duty Cycle ?
5. When its Lean after changing "Overall Fuel Trim" to max (i think 100%) get more Fuel Presure ? and Tune again
Sorry for this Questions but my English is not so good and thats the way i understand it ;). Here in Germany the people wont help me so they will only my Money but i will Learn to tune my Car by my self
You should never have to change your overall fuel trim to 100% If you are making huge changes to the overall trim there is a problem soemwhere. Your pump my not be working correctly or you may have a restriction soemwhere.
Kai-DelSol
ok, that was only an example for me ;)
I have seen some issues on my laptop with Vista.
When i create a Basemap on my Home PC (windows XP) is all fine.
When i change the Injecor size the Injector Duty cycle in the Map also changes.
On my Laptop, when i change the injector size (Windows Vista) it wont change the Duty cycle, it stays a whole over 100%.
Now i have created my Basemap on my Home PC and load it to my Laptop. the Calibration is the same.
Is that a Bug or is the SManage not so good with Vista ?
Kai-DelSol
After creating a new basemap and idle/part throttl tuning the car will not rev over 7k rpm when i try to hit my target AFR. it only runs to max rpm when its around 14-14.4:1 afr on high load.
When i will add fuel to get my target AFR around 12.8:1 on high load, the injector duty cycle comes over 100% and it will not more rev to the max. it sounds like a revlimiter.
here is my currend calibration with one datalog (only in the first gear, i have no chance the next days to drive it on the road for a 4th Gear datalog).
Here is my current setup:
T3/T4 Turbo .50/.63AR , Tial 38mm Wastegate max 8 psi
RC 440 12ohm injectors
Walbro 255 Fuelpump
Stock B16a2 with Blockguard and ARP headstudds
Stock Fuel pressure regulator (i dont know how much fuel pressure i have with the stock one)
I see it going to 7845rpm. You need to check your fuel pressure. Make sure the regulator is boost referenced as well.
Kai-DelSol
The regulator is this little thing on the Fuel rail ?
that is the Stock one. Is it good to buy a aftermarket fuel pressure regulator ?
Well i think that also like you that my Fuelpressure is too low for this Turbo.
I have read that the B16a2 has 35 Psi and a B18 and Second Generation B16a2(OBD2) has 45 Psi Fuelpressure.
I hope the Injectors are Big enough, i wont buy Bigger injectors, these are expensive.
For the First setup, it was a T25/t28 Nissan Turbo planned but this one has cracket and so i only got This T3/T04E Turbo... I think that this Turbo produce much more Airvolume against the Little T25/t28.
Wish me Luck that i can fix this with more Fuelpressure.
I write back when i have test it on Wendsday.
Kai-DelSol
after a few monts and a lot of mony (i have build my complete engine new.. i have blown the piston rings from the stock pistons).
Here my complete New setup:
T3/T4 turbo .50/.63 AR
440ccm RC injectors
255lhp walbro fuelpump
Fuelpressure regulator set to 45psi overall
Brand new Wiseco Turbo pistons
Brand new Eagle H-Beam Rods
Brand new Valves
Brand new Bearings and all Seals
Car is Running smooth but there is a little problem.
In Oplen loop i hit the 14.7 afr in idle and part throttle driving.
In Closed Loop i can´t get it to run to 14.7 afr. it runs everytime around 14.6-15.4 afr.
Idle is fine at 850rpm but in Closed loop at 15-15.4 afr...
Where can be the problem ? the ignition ? a little leak in the exhaust that the wideband reads not correct ? the O² voltage is in Idle and part throttle driving around 0.4-0.6 Volt.
Is my SM-AFR damaged ?
in closed loop it will vary a little, and what you have posted looks fine. IT will just help you get better economy.
