Kpro shuts radiotor fan...help
Posted: Thu Jun 05, 2008 12:45 am
by hydrominal
Hi all, I have a problem with my Kpro. The last time I installed kpro, it killed my radiator fan so I thought maybe its the fan's fault. I tried all means to jumo start the fan, it just wouldnt work. So I changed a new fan. BUT everytime I plug Kpro in, it automatically stops the fan. Only when I plug my stock ecu in then the fan starts to run again.
Send it to 2 tuners, both couldnt find out what is wrong with it. I need help...
Hondata, have you gotten this problem b4?
Posted: Thu Jun 05, 2008 9:35 am
You should not be using the K-Pro to run the fan. Do you have the correct thermo switch to operate the relay that runs the fan?
Posted: Thu Jun 05, 2008 8:27 pm
by hydrominal
Spunkster wrote:You should not be using the K-Pro to run the fan. Do you have the correct thermo switch to operate the relay that runs the fan?
I have a Mugen fan switch and thermstat. Kpro is not running the fan. Thats my point. thats what got me puzzled.
Posted: Fri Jun 06, 2008 9:29 am
Then it sounds like you have some kind of wiring problem. Who did the harness for this vehicle?
Posted: Sun Jun 08, 2008 8:15 pm
by hydrominal
Spunkster wrote:Then it sounds like you have some kind of wiring problem. Who did the harness for this vehicle?
The wiring is stock as I'm driving a 03 Integra Type-R so its a direct fit or so I heard from my tuner. Yesterday, tried the Kpro again and i think its really the fault of the ECU. Both fans are fluctuating, on n off every 5 secs. sigh....
Have anyone gotten this b4?
Posted: Mon Jun 09, 2008 11:55 am
Try unplugging the fan thermo switch. What happens?
Posted: Mon Jun 09, 2008 7:14 pm
by Corey872
Are you sure that none of your nitrous controls are active and/or have output set to B6 - Fan control? Sometimes they have a pesky habit of getting activated accidentally
