Need controls for Electric Power Steering
kommon_sense
Post by kommon_sense »
Installing electric hydraulic power steering using the mr2 pump has become somewhat common.
I was considering using the nitrous controls to simply turn the pump off when cruising on the highway (i.e. 6th gear). Unfortunately the nitrous controls do not support gear selection.
I can not simply set it to trigger at low speeds because the car is also a track car (hpde), so I may have a low speed condition causing the pump to turn on/off mid-corner and changing the way the car behaves unexpectedly.
Any chance of getting gear added to the nitrous controls or getting a set of generic controls that can be customized for whatever a user needs?
