Hello, are there any maps available that I can load onto my s300 that basically replicate the stock ECU operation? I want to break in my newly built motor without boost. I was planning on running a p2p ECU (I have a d16y8/z6 hybrid engine) for the break in, but then I would need to wire in 2ndary o2, knock sensor, and probably some other things just temporarily. I am trying to avoid that as my engine harness is all re-wired.
What are my options to break in the engine with the Hondata? I need to be able to rev to around 6k for ring seating and then it needs to drive decent at least so I can put some break in miles on it.
edit: I am using an s300 in a p28 fyi. The engine is about in stock form right now, stock injectors, fuel pump, etc.
Thanks.
Justin
