Okay so i just socketed my s300 into my P28 ecu with the OBDII to OBDI wire harness and havin trouble finding a suitable calibration for it i tired the stock USDM 98 ITR.skl but it runs like shit. I was wondering if anyone had a setup close to mine or if anyone felt up to the challange to come up with a calibration that would work. Thanks
Here's my setup
Block:
JDM B18C-R
all stock jdm block w/- new pistion rings
- APR Head Studs
Trans:
Usdm B18C1 Trans
-Excedy Stage 2 Clutch :?: :?:
Head:
USDM B18C1 gsr
-Race Port & Polish Work Done
-2 Layer Head Gasket
-All JDM ITR Valves, Springs, Retainers
-Skunk 2 Stage 1 Camshafts
-Head was milled 0.5mm
-Skunk 2 Pro Series Intake manifold w/ stock Throttle Body and short ram intake with a velocity stack attached
-My effective compression is 12.4:1
Exhaust:
-Vibrant 4-2-1 One piece header
-Test pipe 2.5"
-RsR Ex-mag cat back exhaust
12.4:1 N/A B18C Calibration.skl Needed
WarpedSportzKid
- Contact:
WarpedSportzKid
- Contact:
I clearly prefer n/a engine to turbo ones. The sensation and feeling are totaly different. A real good naturally aspired engine have a real breath, you feel a develish fun to rev with it. When you open throttle you're able to instantly hear the air penetrating inside cylinders which seem to make explosions like in hell just next you. A real relation between man and its machine without artificial assitance.WarpedSportzKid wrote:thanks for the props but i've been running my stock gsr ecu until i save up enough money to have somebody tune my s300 ecu for me..
p.s. there's too many turbo'd everything in here aren't there any people who appreciate N/A
Please, let us know if your tuner as done a good work on your S300.
Just a question: what is the gas octane ratio used for your 12,4 rv?
WarpedSportzKid
- Contact:
WarpedSportzKid
- Contact:
WarpedSportzKid
- Contact:
cardinal811
