what wide band should i use AEM or PLX??
671k20a
Post by 671k20a »
WHATS UP! i NEED SOME HELP... I have a 2000 SI W/ a k20aR. I'm not getting any reading of air fuel ratio thats on the kpro. So i plan to buy a wide band, but not sure what to get. Thanks alot in advance.
What is the code on the side of your ecu?
671k20a
Post by 671k20a »
prd
671k20a
Thanks...
Post by 671k20a »
guess nobody wants to help.. thanks anyways...
I would recommend the PLX. This will allow you to use the narrowband output from the PLX for running the car in closed loop and the wideband to datalog.
671k20a
Post by 671k20a »
Spunkster wrote:I would recommend the PLX. This will allow you to use the narrowband output from the PLX for running the car in closed loop and the wideband to datalog.
which plx 100 or 200? And thanks alot for your help.
