Was wondering a few things about my setup:
Greddy Turbo kit w/ Intercooler(believe effective 8psi after IC)
Stock Block B18C1
P72 ECU/Hondata S300
RC 550cc injectors(saturated)
Skunk2 IM
Now, assuming all these things.....
I am looking for a basemap to run this setup.
Will any of the included hondata basemaps run this setup properly(only as a basemap, of course, not going to beat on her till she's tuned)?
If none of the included maps work properly, is there a good one out there?
And, should changing injector sizing with the Hondata tools on such a basemap cause problems(figure most maps for this setup would assume Greddy's smaller 310cc injectors)
Thanks in advance for your time...and your patience with a noobie.
Greddy TD05H-18G on B18C1, 550cc injectors
prepslider69
close to same set up
i have a simi build b18c1 with lowercompression pistions and a td05h 18g turbo with 440 inj. i used the b18c5 with revhard turbo map it ran just had a knock sensor code. if any one has a map that would work better for my set up with would be appriciated if you posted it. thanks
