Random MIL light without any codes
DOHCAccord
Ok, as it says above. I have had two occasions where the check engine light comes on, once while I was driving, and once at start up. When the lights on and I put a jumper at the service connector the light goes off. No codes being displayed. Also, if you turn off the car and then right back on it clears the check light. I am now taking my laptop every time i go driving to try and figure this out, but til then. does anyone have any ideas on this? could it be a protection setup that i have, which is only coolant at 220 degrees to make redline 3k. the car kinda stumbles with the light on, but drives the same, maybe just wierd on the throttle.
