More than 1 rev limiter.
Posted: Tue May 13, 2008 4:54 am
by RickyLee53
Could the S300 be made to have more than 1 rev limiter?
I don't want to change the rev limiter in every gear, just 4th for drag racing. As i'm hitting the limiter just before the line. I want to up it 200-300 RPM's however i don't want to put this strain on the engine in all gears, and miss shifts etc.
Could the program be changed so this is possible?
Posted: Tue May 13, 2008 9:31 am
No it cannot be changed like this. Just set the shift light where you need to shift and set your rev limit slightly higher so that in 4 gear you can just keep going.
Posted: Wed May 14, 2008 1:31 am
by RickyLee53
Spunkster wrote:No it cannot be changed like this. Just set the shift light where you need to shift and set your rev limit slightly higher so that in 4 gear you can just keep going.
Shame, but the problem is, when the car spin's i usually let it hit the limiter so i set it lower.
Posted: Wed May 14, 2008 8:37 am
Set up a nitrous output for maximum ignition retard the igniton below 3rd or 4th gear and 500-1000 rpm before the rev limiting. This will soften the rev limiter in the lower gears if you're getting wheelspin.
