Broken calibrations?
Posted: Mon May 12, 2008 8:11 am
by LK7R
Hi,
I'm having problems with broken calibrations. When I save calibration on my notebook ,close KManager and start up the KManager again and open that saved calibration it is corupted. Any idea what can cause that? Or what can I do in order to get it fixed / to stop KManager doing it?
Car: Euro Civic TypeR 2004
ECU: PRA
KManager: 1.2.3.5 (but it was happening even with 1.2.3.3 and 1.2.3.4)
Windows XP Professional - Czech language
Sometimes it comes up with "wrong value 0.128" could it be something that local setting ("," is used as separator rather than ".")?
cheers
Dan
Posted: Mon May 12, 2008 9:13 am
Yes, it is the localization setting using , as the decimal separator, which is also the list separator.
What are your regional settings, because when testing here it works if I change the decimal separator to ',' ?
Posted: Mon May 12, 2008 9:47 am
by LK7R
Here is screenshot of the regional settings.
It is CZECH but i hope you'll be able to read it from memory.
Posted: Mon May 12, 2008 10:18 am
by LK7R
It is usualy hapenning when I do incremental saves / uploads of an CAL. All works until i quit the KManager. When I open it again - the KAL is corrupted. Will try to fiddle with the regional settings...
Posted: Tue May 13, 2008 7:59 am
It works here, but I think windows is sending new regional settings to KManager at intervals. I've made a change for the next release which should fix this.
Posted: Tue May 13, 2008 8:28 am
by LK7R
Thank you!
Posted: Fri Aug 22, 2008 12:06 am
by LK7R
Just reporting that broken calibration problem seems to be solved.
tested in previous and lastest release (1.2.8.0)
Thank you.
Dan
Posted: Thu Oct 23, 2008 10:16 pm
by Vasily58
Hi guys
I've downloaded a calibration from my buddy's ECU. His ITR was tuned and dinoed at our local Hondata Dealer.
The same story with the older version of calibrations. I went trough all warnings and finally downloaded the cal.
But all the ignition cards were empty.
How can I convert the cal into the newer version (1.3.0.0) of my k-pro manager?
here's the file
Posted: Fri Oct 24, 2008 8:30 am
Looks like security was set. You will need to obtain the original calibration.
Posted: Fri Oct 24, 2008 9:44 pm
by Vasily58
Hondata wrote:Looks like security was set. You will need to obtain the original calibration.
thanks
