Hi,
I'm having problems with broken calibrations. When I save calibration on my notebook ,close KManager and start up the KManager again and open that saved calibration it is corupted. Any idea what can cause that? Or what can I do in order to get it fixed / to stop KManager doing it?
Car: Euro Civic TypeR 2004
ECU: PRA
KManager: 1.2.3.5 (but it was happening even with 1.2.3.3 and 1.2.3.4)
Windows XP Professional - Czech language
Sometimes it comes up with "wrong value 0.128" could it be something that local setting ("," is used as separator rather than ".")?
cheers
Dan
Broken calibrations?
Civic Type R EP3:
http://www.honda-club.cz/forum/garage.p ... cle&CID=37
Here is screenshot of the regional settings.
It is CZECH but i hope you'll be able to read it from memory.
Civic Type R EP3:
It is usualy hapenning when I do incremental saves / uploads of an CAL. All works until i quit the KManager. When I open it again - the KAL is corrupted. Will try to fiddle with the regional settings...
Civic Type R EP3:
Just reporting that broken calibration problem seems to be solved.
tested in previous and lastest release (1.2.8.0)
Thank you.
Dan
Thank you.
Dan
Civic Type R EP3:
Hi guys
I've downloaded a calibration from my buddy's ECU. His ITR was tuned and dinoed at our local Hondata Dealer.
The same story with the older version of calibrations. I went trough all warnings and finally downloaded the cal.
But all the ignition cards were empty.
How can I convert the cal into the newer version (1.3.0.0) of my k-pro manager?
here's the file
here's the file
You'll never get enough horses under the hood so stop chasing them
