EGT Logging
perlmeistere8
EGT Logging
Post by perlmeistere8 »
I see that to log egt's you can use one of the analog inputs (1 or 2) and perform necessary ecu modification. I am running a defi d gauge egt gauge and I was curious if I could T off the sensor wire to run to B6 for datalogging egt's, would this work?
Thanks,
Ben
deafy
Post by deafy »
i'm in the same situation with the same gauge/sensor. No clue how we'd hook it up and whatnot.
1997 Prelude - under the knife.
2000 Insight - k20z3 swap, pt6262, e85. 508whp@19psi.
You cannot just T into the sensor. You must use something like the PLX SM-EGT that has an analog output that you can input the vlaues into the Smanager software.
perlmeistere8
Spunkster wrote:You cannot just T into the sensor. You must use something like the PLX SM-EGT that has an analog output that you can input the vlaues into the Smanager software.
Thanks for the quick reply and thank you for the work that you do!
