help
willyrsx2005
help
Post by willyrsx2005 »
im new please i need help on my rsx-s i install my kpro serial are(5201) i dont know is are the setting or what but my idle are up and down all the time please help me masters.thanks for all
Jpax
Post by Jpax »
if your idle is up and down what did you do to the car?
did you check for Vacum leaks?
you have a map labeled 260hp 8 lbs I m guessing your tuner allready tried to fix it.
fonz600
Post by fonz600 »
post a datalog as well mate. Also what mods have you got?
Bflaker
Post by Bflaker »
Does it lope back and forth from 1000-2000 rpms? If so, its probably your IAC Valve sticking. There is a how to on clubrsx.com for cleaning it. I had the same problem and it immediately went away after cleaning my IAC Valve.
03' RSX Type-S
I/H/E/RBC/K-PRO/100shot/555R's
13.2 @ 109mph w/ 2.0 60'
dustyboner
Post by dustyboner »
willyrsx2005
Jpax wrote:if your idle is up and down what did you do to the car?
no my problem come few days after the little tune,the fale name is before the problem thanks im work with the iac in cleaning them thanks for all im lets you know guys have a nice day
willyrsx2005
Re: help
willyrsx2005 wrote:im new please i need help on my rsx-s i install my kpro serial are(5201) i dont know is are the setting or what but my idle are up and down all the time please help me masters.thanks for all
i cleaned the iac but the problem persist i dont know what happend.
