vx wideband
Posted: Mon May 05, 2008 8:00 pm
by skinny1
I have a vx hatch with a 5 wire o2. can I use this to tune. if so what voltage adjustment/setup selection will I need. (ordered wideband for other car, wanted some practice so I dont blow up built engine)
Posted: Tue May 06, 2008 7:49 am
The short answer is no. A wideband consists of an o2 sensor and a controller. For the VX the controller is built into the stock ECU. For aftermarket widebands, the controller is a seperate box. Controllers must be matched to the o2 sensor type. When replacing the ECU there is no controller for the VX o2 sensor, so your only option is an aftermarket wideband. They are fairly cheap now.
Posted: Tue May 06, 2008 8:07 pm
by skinny1
thank you
