Problem with injector durration and fuel cut
Posted: Mon May 05, 2008 12:01 pm
by Boostoholic
Hi everyone I'm new to Kpro and recently started having trouble with my car. Its an '02 RSX-s with a custom turbo kit running about 8lbs. A few days ago my car started acting up, Whenever i go full throttle it will jerk violently and the RPMs will go all over the place. The only thing different in my DL's is the injector durration is through the roof. If the problem is not in my tune my only other guess is my fuel pump is going and im losing fuel pressure.
Also I dont have a stock primary so the datalogs are using and AEM UEGO
Thanks,
Travis
Posted: Mon May 05, 2008 12:44 pm
If you don't have a primary o2 then you cannot use lean protection. IT will only work using the factory wideband sensor.
Posted: Mon May 05, 2008 12:50 pm
by Boostoholic
Then what would be the cause of my car feeling like hitting fuel cut and my injector duration being so high?
Posted: Mon May 05, 2008 1:31 pm
It is shutting down becuase of the lean protection. Turn it off.
Posted: Mon May 05, 2008 3:17 pm
by Boostoholic
Spunkster wrote:It is shutting down becuase of the lean protection. Turn it off.
I tried turning it off didnt solve the problem :(
Posted: Mon May 05, 2008 4:56 pm
Post the new calibration and a short (under a minute) datalog showing the problem.
Posted: Mon May 05, 2008 5:21 pm
by Boostoholic
Spunkster wrote:Post the new calibration and a short (under a minute) datalog showing the problem.
Will do as soon as I can tomorrow
Posted: Tue May 06, 2008 1:16 pm
by Boostoholic
Heres the new ones for today. I think the problem may be caused by my fuel pump going out giving me low pressure and hard starts.
Posted: Tue May 06, 2008 1:54 pm
That is not under a minute. What is the timestamp where you experience the problem?
Posted: Tue May 06, 2008 2:20 pm
by Boostoholic
The worst case of it is between 5:00 and 5:10
Posted: Tue May 06, 2008 2:39 pm
I don't see any problem at that timestamp.
Posted: Tue May 06, 2008 2:49 pm
by Boostoholic
check the injector duration. I dont think it is supposed to be that high.
Posted: Sun Jun 08, 2008 4:01 am
by SVAILLAN
check for a vacuum leak, do you have a fuel pressure gauge on the rail/what does it say, someone whas having trouble sort of like this and he ended up having a bad fuel filter.
Posted: Sun Jun 08, 2008 5:56 am
by Rallyeman
I had similar problem, try calibrating the TPS!!
