jrsc b18c problems
Posted: Mon Apr 28, 2008 8:10 pm
I am having problems with my jrsc "high boost" setup on my b18c Civic. It is the jdm gsr motor, and I am running a p28 ecu that you guys socketed and installed s300 on. I am running RC 440cc injectors. The car has always had a rich and stumbling idle. When driving the car at part throttle (constant speed), the engine feels like it has an on-off switch. Either I am decelerating or accelerating.
The datalogging file I sent is the car idling. One thing to note is that I have to have the IACV duty cycle at 75%. If it is lower than 50% the car just stalls. From 1:05 to 1:30 in the log file I am trying to hold the car at a constant 2500 rpm's or so. As you can see, the revs raise and drop from idle irratically even though the tps angle is nearly constant.
At 2:04 in the log file it looks like the s300 stopped logging even though the car kept running the same. Strange.
The car has a brand new distributor, and a brand new tps. I tried to set the base timing as best I could with the rough idle. I have a walbro 190 lph fuel pump and a stock reg.
Any ideas I am stumped?
