No VSS on 2006 RSX-S
Posted: Mon Apr 28, 2008 3:00 pm
by john_civic
Hi..
I baught a 02-04 Kpro and I sent it to Hondata to modified for a 05-06 RSX. I installed the harness and Kpro.
Everything is working except my speedo.
I selected countershaft diven speed sensor.
On my laptop the speedo is working pretty good but their is no signal to the cluster...
When I use my OEM 2006 ECU, my speedo is working.
So I check for the conversion harness. E26 (blu/wht wire) is the VSSOUT. On the harness this wire goes to B11 in the PRB KPRO'ed ECU. B11 is normaly non used on 02-04 PRB.
I tried many times to reupload my Kpro, but nothing.
Posted: Mon Apr 28, 2008 4:17 pm
What vehicle is this in?
Posted: Mon Apr 28, 2008 4:25 pm
by Garrett_si
Civic Eg 92-95
Posted: Tue Apr 29, 2008 9:24 am
by john_civic
Garrett_si wrote:Civic Eg 92-95
Right... and I tried on my friend 05 rsx-s. Same problem, no speedo.
Posted: Tue Apr 29, 2008 1:46 pm
by Garrett_si
I suspect a K-pro low frequency output problem....
someone to confirm it?
Posted: Tue Apr 29, 2008 3:09 pm
This is not designed for engine swaps. There is no wiring from the ecu to the speedometer in an eg. Check the output on B11 to see if you get 4 pulses per wheel revolution
Posted: Tue Apr 29, 2008 9:03 pm
by john_civic
Spunkster wrote:This is not designed for engine swaps. There is no wiring from the ecu to the speedometer in an eg. Check the output on B11 to see if you get 4 pulses per wheel revolution
I will check for B11, but it's supposed to work in my friend's 2005 RSX-S(100% stock)
