No VSS on 2006 RSX-S
john_civic
Post by john_civic »
Hi..
I baught a 02-04 Kpro and I sent it to Hondata to modified for a 05-06 RSX. I installed the harness and Kpro.
Everything is working except my speedo.
I selected countershaft diven speed sensor.
On my laptop the speedo is working pretty good but their is no signal to the cluster...
When I use my OEM 2006 ECU, my speedo is working.
So I check for the conversion harness. E26 (blu/wht wire) is the VSSOUT. On the harness this wire goes to B11 in the PRB KPRO'ed ECU. B11 is normaly non used on 02-04 PRB.
I tried many times to reupload my Kpro, but nothing.
What vehicle is this in?
Garrett_si
Post by Garrett_si »
Civic Eg 92-95
john_civic
Garrett_si wrote:Civic Eg 92-95
Right... and I tried on my friend 05 rsx-s. Same problem, no speedo.
Garrett_si
I suspect a K-pro low frequency output problem....
someone to confirm it?
This is not designed for engine swaps. There is no wiring from the ecu to the speedometer in an eg. Check the output on B11 to see if you get 4 pulses per wheel revolution
john_civic
Spunkster wrote:This is not designed for engine swaps. There is no wiring from the ecu to the speedometer in an eg. Check the output on B11 to see if you get 4 pulses per wheel revolution
I will check for B11, but it's supposed to work in my friend's 2005 RSX-S(100% stock)
