Error Codes Not reading In Program.
Funbar
Post by Funbar »
Hey guys.. I'm not sure why, But My MAP sensor isn't reading properly.. it's staying at -20.9. and, My TPS is a bit off... goes to 112%, I'm gonna fix that... But.. For some reason, I can Unplug BOTH TPS and MAP, And I get the CEL, but the they do not show up in the error codes in the SManager Program.... This is on SManager 1.3.4.0.
Why is this?
Funbar
Post by Funbar »
Okay.. For some reason,.. I swapped ECU's with a KNOWN good/working ECU, and It started right up. and Put my ECU in the other car, and It also started right up.. Both Cars ran Fine after that...
But I still Cannot read the codes, if there are to be any....
Are you datalogging when trying to read the codes? Is the check engine light on?
Funbar
Post by Funbar »
Spunkster wrote:Are you datalogging when trying to read the codes? Is the check engine light on?
I'm not sure what 'coeds' are .. But yes.. I'm always Datalogging, Not always recording... And yes, the CEL was on...
Recently.. I noticed I was overheating a bit, and I got a CEL for Overheating and S300 Showed that code... But that's the only CEL I've received since.
