Page 1 of 2
PWM not chipped good need help!!!!
Posted: Fri Apr 25, 2008 7:28 pm
by element
well i just installed a hondata boost solenoid and for some reason we screw up somewhere in the install of the PWM cauz it wont control nothing from boost control in s300 and i tried another ECU that was chipped by phearable.net and it works fine.
here are some pics would be awesome if you guys could tell me whats wrong.
Posted: Sat Apr 26, 2008 1:43 am
by Funbar
Is R71 the correct Ohm'age? 330K Ohms..
should it not be.. 330 Ohms....
Would that likely be the problem?
Posted: Sun Apr 27, 2008 10:32 am
by element
anyone ?
Posted: Sun Apr 27, 2008 6:50 pm
by element
could any admin answer my question or anybody else ? could it be cauz its just a wring ecu and A11 is not grounded right ?
Posted: Sun Apr 27, 2008 7:42 pm
by Funbar
Funbar wrote:Is R71 the correct Ohm'age? 330K Ohms..
I changed the resistor, to a 330ohm.. and still the same problem..
Posted: Sun Apr 27, 2008 10:13 pm
by element
ok well since you guys wont answer to those question, are you guys gonna come up with a fix on that or the best way like i read in another thread is to swap ecu ?
would be nice if you guys let us know, since i know you guys know about it and have read the threads just wont comment on it.
let us know.
Posted: Mon Apr 28, 2008 10:05 am
by TurboGSR96
the birds are still chirping.........
Posted: Mon Apr 28, 2008 10:56 am
Where did you get the components?
We don't know of any random ecus not working, unless components have been installed incorrectly and damaged the ecu.
Posted: Mon Apr 28, 2008 5:09 pm
by element
got the compoments from xenocron.com and we chipped it using the write-up on the help files in smanager ;)
Posted: Mon Apr 28, 2008 9:03 pm
by element
well just talk to john from j-k-tuning.com to order another ecu so i can transfert my s300 and he said that it seems like a pretty common problem and that the pin stays grounded could be the problem or a error in the processor, but hes looking into a way to fix it.
just though id let you guys know
Posted: Mon Apr 28, 2008 9:54 pm
by TurboGSR96
Well the person that installed my components, has installed 30+ of them prior and has also experienced the same issue with 1 or 2, so with all these cases appearing, I doubt its user install error on most of these. Hopefully the issue can be found and solved.
Posted: Mon Apr 28, 2008 11:15 pm
by optix
That's ~10% failure rate. That seems pretty high, even for small-scale operations. Did it work properly at the get-go, or did the problems happen after burn-in?
Posted: Tue Apr 29, 2008 4:58 am
by Funbar
optix wrote:That's ~10% failure rate. That seems pretty high, even for small-scale operations. Did it work properly at the get-go, or did the problems happen after burn-in?
How can it happen after the 'burn-in', when you need those components to use the Boost Controller? How would you know...
Posted: Tue Apr 29, 2008 6:30 am
by optix
Look up the 'bathtub curve'. That's the burn-in period to which I'm refering.
Posted: Tue Apr 29, 2008 10:36 am
If you have used the wrong resistors then you will damage the ecu and it will not work. This seems to be the case here.
Ecu's prepared by Hondata have a 0% failure rate for the PWM output.
