PWM not chipped good need help!!!!
element
Post by element »
well i just installed a hondata boost solenoid and for some reason we screw up somewhere in the install of the PWM cauz it wont control nothing from boost control in s300 and i tried another ECU that was chipped by phearable.net and it works fine.
here are some pics would be awesome if you guys could tell me whats wrong.
Funbar
Post by Funbar »
Is R71 the correct Ohm'age? 330K Ohms..
should it not be.. 330 Ohms....
Would that likely be the problem?
element
Post by element »
anyone ?
element
Post by element »
could any admin answer my question or anybody else ? could it be cauz its just a wring ecu and A11 is not grounded right ?
Funbar
Post by Funbar »
Funbar wrote:Is R71 the correct Ohm'age? 330K Ohms..
I changed the resistor, to a 330ohm.. and still the same problem.. :cry:
element
Post by element »
ok well since you guys wont answer to those question, are you guys gonna come up with a fix on that or the best way like i read in another thread is to swap ecu ?
would be nice if you guys let us know, since i know you guys know about it and have read the threads just wont comment on it.
let us know.
TurboGSR96
Post by TurboGSR96 »
the birds are still chirping.........
585whp/385tq @ 21-23psi E85 Ethanol
OEM GSR Cams & Ignition
Where did you get the components?
We don't know of any random ecus not working, unless components have been installed incorrectly and damaged the ecu.
element
Post by element »
got the compoments from xenocron.com and we chipped it using the write-up on the help files in smanager ;)
element
Post by element »
well just talk to john from j-k-tuning.com to order another ecu so i can transfert my s300 and he said that it seems like a pretty common problem and that the pin stays grounded could be the problem or a error in the processor, but hes looking into a way to fix it.
just though id let you guys know
TurboGSR96
Well the person that installed my components, has installed 30+ of them prior and has also experienced the same issue with 1 or 2, so with all these cases appearing, I doubt its user install error on most of these. Hopefully the issue can be found and solved.
optix
Post by optix »
That's ~10% failure rate. That seems pretty high, even for small-scale operations. Did it work properly at the get-go, or did the problems happen after burn-in?
Funbar
Post by Funbar »
optix wrote:That's ~10% failure rate. That seems pretty high, even for small-scale operations. Did it work properly at the get-go, or did the problems happen after burn-in?
How can it happen after the 'burn-in', when you need those components to use the Boost Controller? How would you know...
optix
Post by optix »
Look up the 'bathtub curve'. That's the burn-in period to which I'm refering.
If you have used the wrong resistors then you will damage the ecu and it will not work. This seems to be the case here.
Ecu's prepared by Hondata have a 0% failure rate for the PWM output.
