Vtec engagement points & Tip in
Posted: Tue Apr 22, 2008 9:54 am
I just got back from the dyno with the Accord and the Hondata work flawlessly. We were able to get the car tuned really well but I had a couple questions regarding tip in mainly. What are the max negative tip in values that I can set?
The issue is when shifting at full speed the engine experiences a rich condition (11.0 AFR) for a moment which causes a bog then it picks up. I tried setting tip in to -15% but it didnt help much.
Also, is there a way to set VTEC at a lower rpm once it has been engaged? My concern is in between shifts I find that it drops out of VTEC and I need an extra 300rpm to keep it engaged. But changing my engagement point any lower than 5700 is not ideal for hp. We tried 5400rpm and there was a big dip in the dyno chart. Hope that makes sense.
I tried the VTEC boundaries but that wasnt the function I am looking for.
