Total NEWBEE question
Posted: Fri Jul 18, 2003 8:14 pm
Ok, I got my new S200 ... a P28 ECU that was converted by Hondata to run in an OBDII car .. I got the Honda Logger software ... I got the programer ... and I got the RomEditor program ...
My dealer created a special base for me ... the engine is a 2000 model B16B stuck into a '97 EX Coupe ... anyway ... aside from all that ... my question is ....
How do I load the base map that is in the ECU now into the editor program to make changes and then back to the ROM ?
Do I take the ROM out of the ECU and put it into the PocketProgramer to pull the map out, then make changes to it ?
I noticed the RomEditor program has a Logging funtion built into it ?
If it does a Logging function, why do I need the HondaLogger software ?
I have not had the chance to actually use the editor program, or the Logger program .. My dealer forgot to supply me with a key to unlock the ECU.... but thats a different issue that I am going to get worked out ...
I am just a little confused about how the editor program actually works ....
Sorry for the stupid questions
... Just need a little help getting started ...
Thanks !
Thanks !
