yet another antilagg question :)
One thing no one seems to know is what the air fuel ratio is supposed to show when your antilagg is set up properly, i would think extra fuel means rich hence why some people blow black smoke, but no matter what settings i try my wide band reads all the way lean. i can build the boost i want with as little as 50% fuel and -30 retard, however im all the way lean, and when i add 300% fuel im still all the way lean, i know its adding fuel because if i set the activation rpm lower then the launch rpm my wide band goes rich and the timing retards as soon as i rev to that rpm. any way whats the proper way? should we be rich under antilagg and if so why arent i with even 300% fuel?
