CTRL/M problem
Posted: Sun Apr 06, 2008 8:07 pm
by Mr Aryan
just noticed that when trying to CTRL/M on the tables, you can only do that on cam angle zero... on whatever cam angle you do the changes, it goes back and do the changes on zero cam angle while you're in other cam angle tables.
even if you choose edit all tables, it will only change the zero degree table.
you may need to look into it!
Posted: Mon Apr 07, 2008 9:11 am
Yes, a bug. Fixed for the next release.
Posted: Mon Apr 07, 2008 9:25 pm
by Mr Aryan
another thing..
in setting, when i set an external wideband and put the values (or whatever i change in the setting), that stays only in my laptop, when i send the calibration to someone else, he won't see the vaules i set-up, and he manually set-up his setting like me to be able to see my AFR values...
i think the setting you put, should stays with the .kal file you create.
Posted: Tue Apr 08, 2008 9:55 am
Yes, that was something we changed for the S300, but there may not be enough memory in the K ECU to do the same.
