just noticed that when trying to CTRL/M on the tables, you can only do that on cam angle zero... on whatever cam angle you do the changes, it goes back and do the changes on zero cam angle while you're in other cam angle tables.
even if you choose edit all tables, it will only change the zero degree table.
in setting, when i set an external wideband and put the values (or whatever i change in the setting), that stays only in my laptop, when i send the calibration to someone else, he won't see the vaules i set-up, and he manually set-up his setting like me to be able to see my AFR values...
i think the setting you put, should stays with the .kal file you create.
