newb injector question
Posted: Wed Apr 02, 2008 7:34 pm
by dwerpk
ok well im new to hondata...
I have a stock LS block
pr3 head with a PnP, oversized valves, and stock b16 cams
440cc injectors
now my question is...
Can I take a stock map and change it to 440cc injectors in the Fuel Trim section and run correctly? Or do I have to change everything over...also what would be a good map to start with? P72, P30, ITR,P61....?
TIA
Darren
Posted: Thu Apr 03, 2008 9:41 am
You will have to properly tune the fuel to get the right air fuel ratios using a wideband.
Posted: Thu Apr 03, 2008 12:08 pm
by dwerpk
but will just changing the injectors from 240 to 440 will the car atleast start up or will i have to basically start from scratch? because of how much bigger the injectors are.
Posted: Thu Apr 03, 2008 8:05 pm
by ITR 1102
You can recalibrate it for the correct injector size. It should start up.
The point he is trying to make is that you can't assume it is safe / good... You need to retune as everything is merely a basemap for a motor, each one will require different values.
Posted: Fri Apr 04, 2008 10:21 am
by dwerpk
alright i know that i was just wondering if you could recalibrate the injectors thanks.
